Half the volume level cause of latest frimnware update
Hello.
I installed firmware upgrade V01.01.35F on my Sanse Clip 4GB. Since then I have a problem with the volume. The maximum setting is not more than half the volume I had before the firmware upgrade.
There has already been a topic about this but the suggested solution doesn’t work for a Sansa clip. The solution was to change the region setting to a non european one. That is not possible on a clip, as far as i know. Is there a solution that gives me the old volume level again on my clip?
Thanks for your reply.
Witk hind regards
Aloys Sanders
