I recently had a problem with my sansa fuzeDownload Free Programsand the problem is that when I turned my fuze on the players onscreen text had symbols on it, and I was wondering if anyone could help me fix this.
Reload the firmware.
Use the Manual Firmware Update method in this thread. Don’t install the updater–this is the last update.
http://forums.sandisk.com/t5/Fuze/Sansa-Fuze-Firmware-Update-01-02-31-amp-02-03-33/td-p/139175
When you download the All Regions link you will get a .zip file. Unzip it and drag fuzeA.bin onto the driveletter that says Sansa Fuze.
