I am currently enjoying my new Sansa Fuze, although there is one big problem.
The SMC, which is the latest version by the way, will not convert videos to my fuze!
I use DownloadHelper via Firefox to get the youtube videos I need, then convert them from flv to wmv. After this I plug them into the SMC and at first everything seems fine. And indeed it was, for the first video worked without a hitch.
Now the conversion bar freezes at 100% and the second bar at 49%, no amount of time remedies this problem and its really getting annoying.
I tried it again on a different computer, same story. First video worked, second did not.
Supposedly the fuze should read wmv’s, but even when I just drag and drop the files into the Sansa folder the player won’t reconize them…
Is their any remedy to this? Do I need to try another file type or something?
I’ve found it quite useful to have Quicktime installed on the computer, as well as Macromedia Flash Player. Sometimes, having additional codecs and capabilities allows your converter access to tools it may need. This isn’t just for the Media Converter.
