Hello there
I ’ have a problem for Formatting my micro card .
When I want for Formatting card appearance this error
guys help me plz
good luck all ![]()
Hello there
guys help me plz
good luck all ![]()
Return it as defective. To your dealer if possible, otherwise to SanDisk. Be aware though, you have to call SanDisk directly for an RMA# (approval) first.
By the way, this is the Memory _ Vault _ board. Should you have any other issues/comments regarding a memory card , you should them in the Mobile Memory, Professional Cards and all other Standard Cards board.
If you are using an SD adapter, make sure you don’t have the write protect tab on the adapter in the LOCK position.
