Follow this procedure when the Sansa Connect Recovery Tool won't work!
I just registered to say Thanks PromisedPlanet for the process to get the wifi radio working on my refurbed connect!!
to coryconklin - since you recently posted that you had found the process to get wifi working on your connect, I thought I’d ask if you’d gotten it to work with wifi. I’m assuming not, since most others are not. Just curious whether a “start over” from scratch of loading the older OS and re-entering Yahoo info (password) might get these things functional again. I haven’t gone that route yet and so far am experiencing the “Can’t find station…” message on my connect that I setup for wifi months ago. Maybe someone will figure out a work around. The connect is still a pretty nice player for cheap. Good luck to you.
You could try this, but I doubt it would work.  More likely, music streaming has been cut off to the Sansa Connect.  Sandisk would have no reason to continue paying Yahoo to provide music streaming to a discontinued player.  I’m actually surprised it lasted as long as it did … probably some contract expired, or something like that.
The Flickr photo stream no longer works as well.
Darn!
Darn!
Access to Flickr “Your Photos” still works, I just tested it.
“Today’s Most Interesting” isn’t working, though I don’t know if that’s temporary.
That’s what I meant. I don’t have any personal photos on Flickr.
I’ve been trying mutiple times to apply these procedures to recover my sisters sansa connect and am now quite stuck. As soon as I connect the device (showing “recovery needed”) to my laptop, the screen changes to “recovering…please wait” and never changes no matter how long I wait. The command line reports “device failed to open” and “Failed to getusbdevicefilename err - 0”.  turning the device off and redoing the 3 button device reset doesn’t help. Any suggestions would be very appreciated. Thanks.
It sounds like you might just be having some basic USB problems.  Have you tried different USB ports on your laptop?  I believe the Sansa Connect requires a “high power” USB port, and most computers, especially laptops, have a mix of high power and low power USB ports.  If you haven’t already, try a USB port on the back of your laptop.
Also, there is now a working version of the Recovery Tool.  It installs the no-WiFi version of the firmware.  The only WiFi feature that will now work with the Connect is Flickr photos (Launchcast audio streams no longer work), so if you don’t care about that feature, you might as well use this version of the Recovery Tool:
http://kb.sandisk.com/app/answers/detail/a_id/863
I’m getting the same error! Can anyone help?
Which error?  Are you trying to use the manual process for installing the WiFi-enabled version of the firmware?  If so, don’t bother unless you really want Flickr photo support on your Connect, that’s all it will give you.  Instead, use the “official” version of the Recovery Tool:
Hi PromisedPlanet
I hope you still around here.
I need the Sansa Connect Firmware pack.
Megaupload is not working. Please send me or upload Rapidshare etc.
Thanks
FARUK
@fktanik wrote:
Hi @promisedplanet
Thanks
FARUK
Did you read, or follow the link in PromisedPlanet’s post directly above yours? :confounded:
Yes, I read it.
But I don’t download this files:
  • everest_initrd_ext_prod_1.1.1.50239.srr.e
  • everest_vmlinux_ext_prod_1.1.1.50239.srr.e
  • yeverest_zap_ota_rel_1.1.2.65799.tar.gz.e
  • yeverest_zap_ota_rel_ext_prod_1.1.2.65799.sig
I need this files.
Thanks
I’m getting the same erroR.
Can anyone help, Please?
F:\Documents and Settings\My Documents\Sansa Connect Recovery>zsi_fw.exe -w everest_vmlinux_ext_prod_1.1.1.50239.srr.e everest_initrd_ext_prod_1.1.1.50239.srr.e
ZSI FW load starting.
Found encrypted file: everest_vmlinux_ext_prod_1.1.1.50239.srr.e
Found encrypted file: everest_initrd_ext_prod_1.1.1.50239.srr.e
Open USB Device start
found a device!
Attempting to open \?\usb#vid_0781&pid_7481#5&3aeb49d2&0&5#{184954e0-9128-11db-b606-0800200c9a66}
opened device!
completeDeviceName = (\?\usb#vid_0781&pid_7481#5&3aeb49d2&0&5#{184954e0-9128-11db-b606-0800200c9a66})
Opened successfully.
data completeDeviceName = (\?\usb#vid_0781&pid_7481#5&3aeb49d2&0&5#{184954e0-9128-11db-b606-0800200c9a66}\PIPE00)
Loading: 1008000 16809984 1754944
Done!
Loading: 4400020 4294967295 1783808
Done!
F:\Documents and Settings\My Documents\Sansa Connect Recovery>zaprecover.exe -t 600000 -f yeverest_zap_ota_rel_1.1.2.65799.tar.gz.e yeverest_zap_ota_rel_ext_prod_1.1.2.65799.sig
Found encrypted file: yeverest_zap_ota_rel_1.1.2.65799.tar.gz.e
Found unencrypted file: yeverest_zap_ota_rel_ext_prod_1.1.2.65799.sig
Timeout device not found
sd card not suport any mobile and computor
Please, the firmware’s files are not are not available on Megaupload as indicated. Users who have available can tell me where I can find them or send me the files ? thanks
more than 10 years later, here I am with an old Sansa Connect I was given a loooong time ago. I accidentally put it in recovery mode and the recovery tool in the website doesn’t work at all - it won’t even completely install the firmware on my PC! I am on windows 10.
This is the error message that appears when the installer goes to around 30%:
“DPInst result: [-2147483648]:”
When I click OK, the dialog box doesn’t go away until I click it a couple more times, and then the installer completely closes.
On top of that, “http://www.megaupload.com/?d=UNLDGZ1N” no longer works! Any ideas what I can do to get my Connect out of recovery mode? I don’t have very high hopes anyone is going to see this reply on a thread that’s been inactive since 2013, but fingers crossed!
I would love to be able to cover this beautiful mp3 player and be able to use it again :smiley:
Thanks in advance in case someone does help!
