Tuning FM radio shows only odd frequencies in the tenths, that is, i.e.: 100.1, 100.3, 100.5 and so on. It happens that I need a station at exactly 100.2, but I cannot tune to it.
What can be done?
Thanks,
Haim
What can be done?
Thanks,
Haim
See this thread: FM Radio problem, only uneven decimals.
You must not be in the U.S., because radio is at odd freq. there, even elsewhere. You’ll need the firmware with the “F” at the end of the filename… you should be able to get the one you need here
http://forums.sandisk.com/sansa/board/message?board.id=clip&thread.id=10533
I’ll do as you suggest later on. In the meantime, my problem has been solved by eliasf’s answer. I would never had been able to work it out alone. Thanks to you both.
Haim
PS: It is Israel
