Hello, I have a problem with the FM player in my Sansa Clip.
I can only select frequencies that end in an uneven number ie. 99.3, 104.9.
Is there any way to change this?
Thank you
Thank you
Welcome to the forum.
It sounds like your Clip’s radio is set to US mode. Go to Settings > FM Settings > FM Region and select “World”.
In North America, all FM broadcasting is done on the odd decimal frequencies. By only scanning these frequencies, the auto scan speed and accuracy is improved.
However, some Gymnasiums may broadcast the TV feed on even frequencies, and in otehr parts of the world the even frequencies are needed.
So you can choose to set the World FM region for those circumstances.
Message Edited by sansafix on 11-26-2008 10:17 AM
Thank you very much, I should RTFM…
Works wonders now.
