I bought a Fuze. I’m quite happy with it except for one thing. The Radio.
The radio frequency goes in 0.2 increments to odd number channels only! For instance, 95.1, 95.3, 95.5, 95.7, 95.9. That might be fine for the US of A but it’s not fine for other countries like the UK. For instance, Capital FM uses 95.8 and many others that use “even” number channels. I would really appreciate it if your next firmware would allow access to these radio bands. It really ■■■■■ having something crippled on such a great player.
Are you using the European firmware notated with the ‘f’ suffix? Check you firmware version (SETTINGS > SYSTEM SETTINGS > INFO). If the top line ends with an ‘A’ you have the American firmware version and this could be your problem. You can change the firmware here. The European version has an ‘F’ at the end denoting FM. There is also an ‘E’ version (European without FM)
