Product: Clip Zip Firmware: 01.01.17 Basically instead of the Song title appearing in the playlist, the song is listed under its filename. Now I know it’s not an issue with the mp3 file itself because these songs worked perfectly fine on my old Sansa Clip+ I should mention that I used msc mode when I loaded the files as mtp mode was MUCH MUCH MUCH WORSE WITH THIS. I’ve checked the file properties of the mislabeled songs and all the details checked out. What’s going on?
you will need to make sure the ID3 tags are correct on the songs. If the ID3 tag info is missing the clip zip will sort by file name.
Said songs are a select few out of a album in which every other song works properly.
Also I checked the ID3 tags. g2go
And again, the song titles were presented properly in the Sansa Clip+
can you post a link to one of the files with the trouble so we can take a look at it?
Sure, I’ll put it on mediafire. Don’t know how long the link will last for though. Here’s the link: http://www.mediafire.com/?b4a85ucrdoco9mu The song is titled “Sad Waltz” The filename is “19 Sad waltz” Should mention that mp3 info displays fine in wmp and windows explorer
The ID3 tag of this file is ID3v2.2 and was created by iTunes. It needs to be ID3v2.3 IDO-8859-1 for your Sansa player to be able to read it. Other programs like WMP, etc. are more forgiving when it comes to tags. SanDisk mp3 players are not.
You might also consider blanking out the Comments field and changing the Track # info. This tag indicates 19/21. Your Sansa player can’t read that.
The overwhelming recommended dedicated tag-editing program around here in MP3Tag. It’s free and works great. Don’t rely on iTunes.
I see, thanks. I’ll try out the program. So why did that Sansa Clip+ have no problem with the songs though?
So how do I use mp3tag anyway?
How do I go about changing the tag version?
Mp3Tag is very easy to use. To change the default format of the type tags it writes, go into the Tools menu and set it up like fellow Guru, Marvin_Martian so generously posted here.
You can simply open up entire folders, highlight all the tracks and then hit the SAVE icon to automatically change and save them to the new default Write setting ‘en masse’. You can also blank out all Comments fields this same way. To change your track numbering format though, I think you’ll have to do that one by one.
You can actually open up the MP3 files in Windows Explorer if you connect your player to your computer. Right-click on the file, then select properties, then the ‘Details’ tab. This brings up all the tag info, which you can usually edit directly in the field. Put the song title in the ‘Title’ field, & the artist name in the ‘Artist’ field. Sometimes, if the file is read-only, you will have to de-select the box under the ‘General’ tab. If this doesn’t work, you can download MP3tag for free.
When I connect my computer to my player, & I call up the MP3 files on Windows Explorer, MP3tag appears as an option when I right-click on the files. So via Explorer, I can view & edit the files either through Properties or MP3tag.
