Hi. I’m someone else, but I have a similar issue. I decided not to start a new topic :D.
I just got a 4GB clip. I have an m3u file (sample bellow) with ogg files and it shows up emptywhen I use it with audiobooks.
The audiobooks are oggs, they contain the vorbis comments, they have the Audiobook tag.
I put the playlist right along side the files in a subdirectory of the AUDIOBOOK directory of the root of the player.
The tracks show up in the audio book selection under the music menu. They are out of order when I pick the particular audiobook I want so I would like to use the playlist.
When I go to the playlist selection, the playlist I created shows up, but it is empty. I’ve tried just moving the whole directory with the audio books in it into the MUSIC directory.
I am transfering all the files in MSC mode in Linux. I used Mp3tag to create the m3u files in linux under wine. I tried removing the EXTINF lines but it did not work.
If I put regular music ogg files and a playlist for them in some structure under the MUSIC directory,the playlists work great.
My best guess is that at this point it has something to do with the audio book tag and the processing of those files. What I should try it to convert the audio book into mp3 and see if I get the same problem (I suspect I will?).
Here is the sample:
#EXTM3U
#EXTINF:690,01 - Harper Audio Presents - Simon Winchester
01-harper_audio_presents.ogg
#EXTINF:727,02 - A Born-Again Science - Simon Winchester
02-a_bornagain_science.ogg
#EXTINF:327,03 - The View From On-High - Simon Winchester
03-the_view_from_onhigh.ogg
… and so on
Message Edited by Martin__ on 07-02-2008 09:47 AM
Message Edited by Martin__ on 07-02-2008 09:48 AM
