Extreme PRO 128gb not recognized anymore
after around 3 months of use, my USB Drive Extreme Pro 128gb stopped working.
The device is not recognized by IOS (it is not appearing in the device list, disk utility or terminal prompt). When connected, nothing happens and the stick keeps heating up until extremely hot. The blue led light remains ON but NOT flashing.
On Windows, I get a “unrecognized USB device” error message but nothing happens either. It’s not showing under USB devices or anywhere else.
I have tried recovery software, changing several laptops, etc. but no solution.
This is incredibly disappointing since I lost tons of data… I am literally crying now. What should I do? Thanks for your advice.
Hi @andzec,
Please refer to the article SSD drive is not detected in the Windows or MacOS:
https://support-en.wd.com/app/answers/detailweb/a_id/24940
Please contact the SD Technical Support team for best assistance and troubleshooting:https://kb.sandisk.com/app/ask
Try to avoid using the USB drive any further as it may cause further damage and make it harder to recover any data that might be left on the drive.
Check the USB port: Try using a different USB port on your computer or a different computer entirely to ensure the issue is with the USB drive and not the port.
Check for physical damage: Inspect the USB drive for any visible physical damage, such as cracks or breaks. If you find any damage, the USB drive might be irreparable.
Test with a different cable: Try using a different cable to connect the USB drive to your computer as the cable itself could be damaged.
Check in Disk Management: Open Disk Management on Windows or Disk Utility on macOS and check if the drive is detected. If it’s detected, try formatting the drive.
Data Recovery Services: If none of the above steps work, and if you have valuable data on the drive, you might consider contacting a data recovery service to recover any data that might be left on the drive.
Since the drive is heating up and not being recognized, it might be suffering from a hardware failure. So, it’s best to disconnect it immediately to prevent any further damage. This blog post discusses some very basic solutions for USB drives not showing up on Windows. Perhaps you can try fixing it yourself at home.
However, if your computer cannot recognize the USB drive, data recovery software is unlikely to be effective. In this case, I recommend saving your money and reaching out to a professional data recovery service instead.
I would recommend using the Disk Management utility to access the SD card on your system. It is used to manage the drives installed in your system like flash drives, and internal and external hard drives, and to format and partition drives, assign drive letters, delete partitions, change a driver’s file system, etc.
Your SD card might work if in case you choose to format or you choose to change the drive letter associated with it. Check out this article to fix the USB device not recognized error.
I believe your USB drive has suffered a serious physical hardware failure. The system’s complete inability to recognize it means the computer cannot establish low-level communication with the USB drive’s control chip. All conventional data recovery software, computer and system replacements are ineffective at this point, because software recovery relies on the computer recognizing the hardware.
Please unplug the USB drive immediately. If you decide to recover your data at all costs, please seek out a professional data recovery service in your area with an independent laboratory. If the USB drive is not severely overheating, you can try the methods mentioned in this article: How to Fix USB Flash Drives not Showing up in Windows
