Easy question from newbie
I just bought a (supposedly) new Fuze 8GB from Best Buy, but it had a bunch of music files already in it.  Is the Fuze supposed to come with pre-loaded music tracks, or did I get a used/refurbished product?
Thanks.
JEP
Message Edited by TomJensen on 05-03-2010 06:56 PM
Message Edited by TomJensen on 05-03-2010 06:55 PM
mine come with pre-loaded music and a video, and my was in a plastic *hard* sealed from a etailer
so yes, its much like the “■■■■” you get on your brand new laptop or PC from HP
btw while your new you should check out
Video4Fuze = Best way to convert videos for fuze
http://code.google.com/p/video4fuze/
YAPL Fuze = Best way to edit playlists on fuze
http://forums.sandisk.com/sansa/board/message?board.id=sansafuse&message.id=33331
Tom,
Thanks for the reply.  It’s not odd that a brand new Fuze would come with 17 pre-installed MP3 files and 2 pre-installed movie files?  This is normal?
(By the way, as someone whose most recent music is from bands that broke up 20 years ago, I deleted all these files.)
JEP
Yes, it’s normal. SanDisk wants you to see that it can play music and video. The bands think you’ll like their music.
To get rid of them all at once, go to Settings/System Settings and Format.
Thanks. everyone.
