Earbud Stopped Working
I have 3 clips and standard OEM earbuds. On one the R bud just quit working.I handle them carefully.Any way to fix or troubleshoot, or just replace?
I think if the other headphones work on the one with a broken one. We can replace it. I love the OEM buds though.
I did take it apart at the bud to see if solder joint had broken but it was intact. Moving cord showed nothing. Assume either burned out or a break somewhere in bvetween. May try checking contituity with a meter, but now am just using one of the other two sets since cant use 3 clips at a time anyway. If need be, I will just get a newset.
