sammutp
September 14, 2010, 2:40am
1
Looking for a clue here…
My e280v2 corrupted itself to the point where upon powering up, it get stuck in the refresh database window. Can’t do or access anything.
How do I reset the beast?
For the time being, I can only power it on and off…
Can’t beleive I’lost 7 GB of MP3, video and recording.
Anyone?
Thanks
Connect in MSC mode and run ChkDsk. It may be able to find and/or repair whatever is causing it to hang up.
Although the problem could be tag-related . . . When the player freezes during the database refresh, it usually means it’s encountered an ID3 tag it cannot read.
sammutp
September 14, 2010, 2:49am
3
I would very much be able to connect it in MSC mode, but I can’t access anything… It is frozen in the refresh database window…
Follow the “Force MSC mode” instructions here .
sammutp
September 14, 2010, 3:11am
5
It worked!!! Thanks a lot
I guess you are right about faulty MP3 ID tags…
My e280v2 is back to life, thanks to you.
I feel I have the latest firmware: v03.01.16A. Before triyng an upgrade, I will chech my files.
Thanks again
Glad it worked for you!
v03.01.16 firmware is the latest & greatest so it seems you’re good to go.
