e200 Freezing halfway through database update
After transfering some sonds from computer to the player, the player went to “Refresh Database” screen, which is normal, but about 3/4 of the way through, the screen goes white, with some fuzzy looking lines in it. I’ve left it like this opfr hours thinking it might correct itself. It doesn’t.
I have to hold the power button in for about 10 seconds just to shut it off. When I power it on, same thing, tries to refresh database and freezes about 3/4 of the way through.
Is there a way to bypass that database screen (like with key combinations or something) and get right to the menu so I can try to format? Or what else can I try?
I fixed the problem. I used a tip on one of the ther posts that linked to this site: http://www.fixya.com/support/t130441-sansa_e200_load_main_image_failed
Followed those instruction and now it’s working! Thanks to the user that posted that link
