I have a cd that was given to me with the songs converted to mp3 files.
I would like to download this cd to my Fuze like I would a store bought cd using Windows Media Player.
How do I do this? How do I set up a folder, get the cd info, etc.
The data on the CD is in mp3 format then. You can transfer the mp3s to your Windows Media Player library and have a look at them. Of primary interest is whether the files have proper ID3 tags on them.
An easy way to do this is to download and install MP3Tag, and have a look at the files. MP3Tag can be set to output (write) the tags in ID3v2.3 ISO 8859-1 format, which works best on the Sansa. You can even add album art using the utility.
As far as transferring the music to your Sansa goes, that’s the easy part. First, be sure that the MP3 files have tag data embedded, since this is how the Sansa catalogs your music. All you need do is drag-and-drop the files to the Sansa’s Music folder.
Bob :smileyvery-happy:
