downloaded mp3's do not show on the clip
I can download my mp3’s as always into the podcast file opend on the computer, when I have the clip attached to it.
and they also show in the file on the computer when I checked later. But when I disconnect the clip from the computer, the mp3’s do not show on the clip???
Do I have to reformat or should I turn the clip back to the original settings?? or any other ideas what this could be
I can play the old mp3 on the clip fine , just can not add new one’s!!!
Thanks for any tip
San
Those podcasts are probably on your player and listed as unknown, since they are missing title tags. You need to edit the tags on your pc. You can use the free program mp3Tag to do this.
http://www.mp3tag.de/en/
Hi Jk,
no I do not think that’s the problem as I downloaded diverse stufff and some are recorded sessions that I keep downloading and never had this problem.
I checked through my clip again and when I go through the Menue into files and then into Podcast there I find them!!!
But if I go directly in the menue into Podcast they do not show ???
Isn’t that weird - what could that be??
well at least I know how to find them now but still would love to repair this
thanks
@sanjula wrote:
Hi Jk,
But if I go directly in the menue into Podcast they do not show???
thanks
Yes, it is. If you can find the files using the Folder navigation, but not in the ‘normal’ lists that are populated by the info contained in the ID3 tag, then that means the player cannot read that tag.
Podcasts are not exactly known for their pristine ID3 tags, and because of this and the fact that they are gernally listened to once & then deleted there was a huge outcry here on the forum a year or so ago for Folder navigation. Sandisk finally relented and added it in a firmware update for the Fuze and it became ‘standard equipment’ on the Clip+.
It could be that the tags on some of your downloaded podcasts are of a format that your player doesn’t like. As mentioned, MP3Tag is a great (and free) little program to check and/or edit the tags. The best format is ID3v2.3 ISO-8859-1. I’ll bet if you poked around, you’d find that some of those files have some sort of problem with the tag, and that’s why your player is not displaying the info.
“no I do not think that’s the problem as I downloaded diverse stufff and some are recorded sessions that I keep downloading and never had this problem” So those were tagged properly. Sometimes they aren’t.
" checked through my clip again and when I go through the Menue into files and then into Podcast there I find them!!!
Isn’t that weird - what could that be??"
Not weird at all. Tags are missing,  or tags are incompatible with the Clip+. Edit the tags.
