First of all I’m sorry if this question has been asked, its just that its very to search for a problem like this.
I own a Sandisk Ultra 16GB DOK for more than 6 months I believe. Yesterday I plugged it in my PC but it caused problems: at first the drive did not show up, after that it did show up but I couldn’t see any of my data. Regardless to say I can’t even transfer any files into the drive.
When I plug it in, at first it blinks in a short time interval. After about 10 seconds, a smaller portion of the LED is blinking.
Notes:
I’m using XP
About 1 month ago (or maybe more) I messed with the DOK settings and set it to “optimize for performance” (in the device manager) so I could format it to NTFS (I think) and transfer large files.
I tried reverting the above setting to “optimize for quick removal” and then format it, but it could only be formatted to 64MB. I prefered not to mess with it.
Edit: as I suspected, the problem is with my computer. The DOK is recognized on another computer. I tried resetting of course, it didn’t help. I also tried uninstalling the driver (device manager) and then reinstalling it by plugging the DOK back in. Didn’t work.
Thanks for your help!
