Dear Sir/Madam,
I am going to upgrade my laptop to a Windows 8 version. Is my USB going to be compatable with this OS?
Thank you
Kind Regards
Lee
Dear Sir/Madam,
Thank you
Kind Regards
Lee
Probably. Especially if it’s working on the hardware now. My old U3 flash drive works in my wife’s Windows 8 machine.
Are you using SecureAccess on it?
Hi there,
thanks for the reply.
I don’t lock my thumb drive
This should work. Although I haven’t seen one working before. Just make sure that the OS is updated since it will use the Windows drivers in order for the drive to work.
