I bought a 16GB Cruzer Switch to store my files, but after starting the process of copying my files onto the flash drive, I notice it says it’s compatible with Windows XP, Vista, and Windows 7. Does anyone know if it’s compatible with Windows 8?
Not sure yet. Windows 8 should have the preloaded drivers to support it. Try running Windows update and see if it helps. Also, please try checking if theres a driver that you can manually download for this stick.
