I just picked up a 32gb Cruzer Fit yesterday and proceeded to transfer some music files to it so I can just leave the stick in the Kenwood HU of my car.
I formatted the drive for FAT32. I then created a sequence of folders by letter of the alphabet then dropped all my artist folders into their corresponding letter folder.
I plug my drive into my head unit and can access all my artist folders up to the letter M. When I reach M, I can only drill down inside one level, seeing all the artist folders inside M. However, I have no further access from there. I cannot drill down into the artist folder and select any music.
This happens for ALL folders after the letter M. Very weird. I tried removing the M folder, creating a new one and adding just a couple of artist folders inside. After that, I still can’t drill down any further in that folder or any subsequent folders.
When I plug the dive into my computer I can see that there are indeed filed in all of these folders. I can even play the music from said folders on my computer.
I’m not sure if this is a SanDisk issue or an issue with my Kenwood HU, so I am posting in forums for both manufactures.
I think your problem stems from the 26 A-Z folders. This is really unnecesary and your stereo unit in your car may have a database limitation that you’re hitting when you get to the letter M. Without these, the Artist folders would still be sorted alphabetically so I don’t see the need, or your purpose in creating a more extensive folder/file hierarchy.
Eliminate the ‘letter’ folders and see if that doesn’t solve your issue.
Hmm, that didn’t seem to work either. I moved everything out of the A-Z folders and now some folders I can access and others I cannot. It starts in the middle of the J’s. Between Johnny Cash and Them Crooked Vultures I can’t access anything, but everything after TCV I can access. The folders appear, I just can’t click into them.
I checked all the permissions for each folder and they’re all the same with read and write access unlocked.
I did some research on the the head unit as far as USB specifications and everything looks to be compatible.
I’m still waiting to hear something from the Kenwood people.
