I want to put a 13 min. (6GB) video on my drive but it says the file is too big. How?
This is due to FAT32 limitation. Files larger than 4GB cannot be stored on FAT32 volume. Simply format the drive to NTFS.
thanks for the help
Consigo acessar o pendrive no micro do trabalho, mas em casa ele não é reconhecido. O que devo fazer?
Você tentou usar todas as portas USB de seu computador?
Você recebe alguma mensagem de erro?
Você pode contactar seu apoio de tecnologia. Somente clique no elo abaixo
Hi, I had the same problem and I followed the instructions that you posted jamieson and I was able to get the big file onto the flashdrive but now my ps3 cant recognize the flash drive. does it not recognize a fat32 device? thanks for the help.
It would appear the PS3 can’t read NTFS formatted drives. Check the PS3’s documentation, see what it says that it can read.
