Welcome to the tag nightmare. I only wish it was so intuitive as to play in alpha sequence, but that is a coincidence and it is playing in order of some god-awful nerdy imbedded tags. You can find a hundred posts on how wonderfully easy it is to edit them (not so on a Mac), as if it were reasonable to have to edit each of a hundred postcast files just for a one time listen in proper order.
To bad you and I didn’t get a clip+ instead of a clip which ignores folders. I keep returning to this forum in vain hoping to hear they updated firmware to recognize folders (dumb of me, partly because any update announcement is buried inside a topic). I just demote my 8gb clip to be a flac-server which is so wasteful of space that it holds just a few songs that fall in a single genre anyway and are suitable for a random play-all (so no navigation needed).
Message Edited by daft on 01-29-2010 04:03 PM
Also, I should point out that, if you play all songs from a particular album, the songs play in the EXACT order as you would find on the CD. But, if you Play All, you get all the songs in alphabetical order.
On older players, such as the Sansa e130 (which I have), it plays only in alphabetical order, whether you play all the songs on your player or all the songs from a particular album.
I am hoping you can help. I have a Sansa Clip 8mg mp3 player but on Win 7 I just tried connecting to pc and it is not working properly. I can see it recognized on computer but it does not bring up the Sansa menu for storage info and controlling the files. It also is not showing up in my Windows Media Player as connected but is. Suggestions??? I have already updated the firmware on my mp3 player.
Try changing your USB mode (Settings > System Settings > USB Mode). Updating the firmware will revert the player back to its default setting, the infamous and troublesome Auto Defect mode.
I have changed settings to auto detect and to MTS to get computer to recognise device but the menu that pops up on pc never comes up on it. Seems computer related as my laptop works fine. My pc though does not and that is where I need to use it with. I am using latest version of Media Player on machine too. For some reason I do not get that manage device menu though when I plug in player like I should. Sigh.
Have you tried MSC mode? NEVER use Auto! MTP is only needed if using ‘protected’ or otherwise DRM-cripple files, like those from Rhapsody, Audible or other subsrciption services. If you don’t use any of these type files, you’re much better off using MSC mode where your coputer sees the device (and card, if installed) as any other flash-based external drive.
Note your computer can only see files while connected in the mode in which they were transferred in. So while connected in MSC mode, you will not be able to see or access those files that may have been added in MTP (or Auto that defaults to MTP whenver possible) and vice-versa.
I think you missed what I said in last message. To get computer to recognize player I have to put in MTS mode. However my point was it does not matter (in regard to getting the Sansa menu to initiate) what mode I put it in. I do not get that Sansa menu to start up regardless. However same player when I connect to laptop on laptop initiates that start up menu on Laptop to control files. Such as too see battery charge, prompt to start up media player, read manual of sansa clip, etc. This is very annoying as I cannot get my computer to work with my player.
Seems that on laptop I only get that menu with MTP USB setting.
Btw…both laptop and pc run Win 7 with latest media player.
Do you mean MSC mode or MTP mode? There is no such thing as MTS. MSC should always work, MTP depends on what media player and windows updates you have installed.
