Clip+ doesn't turn ON while in USB port (charging)
Hi!
Been happy with listening FM loud enough thanks to this forum (had a problem with low volume), but everything was OK till battery lasted… On FM mode that was some 6 hrs. Than I connected player in USB port of computer, but can’t turn it ON now. What would be the solution? It’s not possible that it can’t be used while charging.
The player will play while charging if you use a cell phone charger or other AC usb charger, or a usb battery pack to charge it.  It will play while charging from the pc if you use a power only usb cable. When the player makes a data connection with the pc, then the player can’t be turned on.
OK, thanks. But in that case manufacturer should provide power only USB, too.
Is battery lasting OK, 6 hrs in FM mode? How much should it be in playing .mp3’s mode?
I’d love to know how you use yours Miikerman, to get 10 hours!
I have two Clip+s and both top out at around 6 hours (4 - 6 hours is closer to the range) - they were refurbs so I thought it was the price I paid for getting refurb, but then I got the ClipZip, *new*, and it still gets about the same.  Listening to all the battery life comments on here, I’ve accepted the 6 hours is pretty normal.
The battery life will gradually get lower (less) as it ages with use; that’s natural. I never benchmarked my Zip, but my Clip+ got 11.35 hours when it was fairly new AND playing 100% FLAC files. With .mp3’s it certainly would have been higher, probably closer to the 15 hrs. as claimed by SanDisk.
Yesterday got some 7.5 hrs of FM, but that was just after full charging and with almost any activity on player but turning it on.
Can volume level affect battery lasting? Because I’m listening it on max. via my office speakers (not on max. off course:)). Or FM signal power? That should make difference, too.
That does seem quite normal, at least from my experience: I usually see about 6-8 hours run time with the Plus and Zip before they get hungry for a recharge.
Running encrypted WMA plus the EQ takes a little more processor overhead than MP3. The FM chip consumes more power as well. On the Zip, the RDS function plus digital out from the FM consume a wee bit more.
Since the latest two Clips have a slightly more confined interior, the battery is a little smaller as well.
Bob  :stuck_out_tongue:
To get the most battery life from the Clip+, use mp3 files. Other file types, especially protected wma files will eat battery power much faster. Keep the screen brightness at a minimum(as low as you can while still being able to see the screen). Set the screen time to a low number. Set the equilizer in the neutral(off position). Let the player play albums straight through, rather than choosing individual songs. Press buttons as little as possible.
If you still need more battery life, then get a usb battery pack. The $30 Veho Pebble XT is  compact, and will probably give around 10 full charges to the Clip+. The Clip+ will play while it is charging if you use a usb battery pack, an AC usb adapter(even a mini usb cell phone charger), or via a pc if you use a power only cable. USB battery packs usually come with a power only usb cable. Another good usb battery pack is the $15 Tekkeon mp1580. The mp1580 uses 4 nimh AA batteries(not included), which makes it larger and heavier than the Pebble XT.It also holds less power, however one can carry as many extra sets of charged nimh batteries they want. The Pebble XT has a built in Lion battery.
@miikerman wrote:
 And another external power source I’ve used:  the Lenmar PowerPort Mini, at around $15 shipped (originally could be found for around $10 shipped).  The nicest thing about it:  about the size of the Clip itself, so a good accessory for it; and with more than enough power for the Clip.
http://www.amazon.com/gp/offer-listing/B00178NJRA/ref=dp_olp_all_mbc?ie=UTF8&condition=all
Nice compact design for sure, but not very good reviews on it though. :cry:
I have the Powerport mini. It ■■■■■. It is very low capacity, and loses plenty of power while idle since it doesn’t have a power switch. Avoid all usb power packs without a power switch.
I’ve never used on of these devices; how long does it actually take to re-charge a depleted Clip+ or Zip for instance? And how do you know the remaining juice left?
A usb battery pack typically puts out from 500 ma to 1,000 ma. i think mine put out around 800 ma. The higher ma output enables faster charging. It takes as long as a good AC usb adapter takes. I guess a full charge takes around an hour or so? When using a usb battery pack, I am typically charging while playing the player,and don’t charge from empty.
Back to you again on this issue… Can’t do that! Tryed other two options with USB settings, auto and MTP, but when I go into MUSIC folder, it shows nothing, like it’s empty. And folders are recognised only in MSR mode.
Despite your effort, actually no.
I’ve tryed seeing my files (.mp3’s in MUSIC folder) in all 3 modes, but nothing. In MSC mode I can see folders, one of them is MUSIC folder where my .mp3’s suppose to be, but they aren’t there. And they are there when player is not connected to the computer!
(Now I see that I wrote MSR in stead of MSC at first, sorry…)
Player was set to MSC mode when I loaded .mp3’s on it.
Assuming the files are still on the player at all (can you play them?), this probably means they were actually loaded in MTP mode, not MSC mode.
Yeah, definitly can play them!
But if I loaded them in MTP, why can’t they be played (and visible) via comp in MTP?!
The issue may be that the files are corrupted because the player was removed from the computer before unmounting.  You may need to reset the player, but first I would try and just copy the files back onto the player.
If this were true, I doubt that they would be playable as mirko says they are.
Yeah, if they are corrupted, wouldn’t be playable at all. Probably.
But just in case I’ll do that, delete all and reload them. What would be reseting the player? And, just to be mentioned, I’ve formated player while it was new, before any file loaded. Could that mean something?
It could, How did you do it? And did yo do it as FAT32?
