Clip Battery Lifetime ....
I’m using the SANSA CLIP for 5 months. All fine … but the battery …
Seems that it provides less and less hours of playing music.
Should that happend ?? and if so …
How many hours a 100% full battery should play (after 4 months of average usage) ??
Thanks
Boaz
@miikerman wrote:
Depends on your settings and music format; generally, tho, well over 10 I would imagine.
The official rating is 15 hours for continous playback of 128 kbps MP3s. I don’t know how much the different bitrates/formats affect this, but I guess your estimation is within reasonable bounds. :stuck_out_tongue:
Also, I doubt 4 months of (even heavy) use are enough to degrade the battery performance. If there is significant drop in capacity, it’s either a defective unit or a calibration issue.
this
