so, the other issue I have with the Clip+ on a rather frequent basis is sometimes the audio will cut out completely and I will be unable to pause or play the song or really do anything until I power off and then power on again. Upon power on, the music will resume as if nothing happened.
I have this issue as well. I usually see this when playing a long audio file such as an audiobook from Audible. I’ll be listening and all of a sudden, it will power itself off. I turn it on again and it continues playing. There are other issues with long audio files as well. For example, after a while, the pause/rewind/fast forward will not work. You literally have to power it off and on again, after which the controls will work for a while.
