Is there another way to charge a Sansa Clip? We are going on a 10 day trip and will not be taking a computer along, and therefore will not have a USB port to plug the Sansa into to charge.
Thanks in advance for your help.
Judy
Judy
There are travel chargers out there in the stores, which allow you to charge USB devices from the wall socket. Provided that you’ll have electricity on your trip, you could look into buying such a charger and use the data cable you’ve got with the Clip to charge it from the wall socket.
It should be available at stores that sell electronics, computers, etc. A wall charger would also allow you to use your clip while it’s plugged in rather than lock up in Data mode when it’s plugged into your computer. There’s a way around it on the PC, of course, but still. ![]()
Thank you!!! I knew someone would know. I’m not very technically oriented.
There are car adapters as well.
http://www.google.com/products?q=car+usb+adapter&oe=UTF-8&hl=en&freeship=1&scoring=p
For the AC adaptor only (the cable is different, made for the Sansa SlotRadio player), check this wee beastieout.
I like the AC USB adaptor packaged in the kit, only $14.99.
Bob ![]()
