Can't view files on microSD card in 4GB Sansa Clip+ when connected to PC
Hey everyone, I was wondering if anyone here has had a similar issue and what you were able to do about it.
I was going to add some music to the 16GB microSD card inside my 4GB Sansa Clip+, but I can’t view any of the folders/songs that are currently on the SD card when I have the player connected to my PC. There doesn’t seem to be anything wrong with the SD card because I can still view and play the music that’s on it through the Sansa itself.
The SD card is even listed in Windows when I connect my player, but if I open it, nothing else shows up. No folders or songs are displayed.
Can anyone help with this?
Settings/System Settings/USB Mode. Try both MTP and MSC. Your computer can only see one at a time.
