Why can you not browse Podcasts & Audiobooks by folder?
My old Clip + was quite happy to do this. I’m used to dropping all my podcasts into a folder. As the podcast software puts the date in the filename, this allowed me to play all the podcasts in chronological order.
I had just assumed that the clip zip would do the same. But the folder appears empty.
The only way I can get these files to appear is by manually removing the podcast genre tag.
This seems ridiculous. Why limit what files are viewable in the folder view in this way?
Short of manually removing the podcast tag from every file downloaded can anyone suggest a better workaround? I’m seriously considering returning my zip.
