I recently purchased a used Clip Zip off of Ebay and I am having difficulty deleting the existing .mp3 files. I can format by using the feature on the device and I can also physically delete the files through windows explorer but as soon as the device is rebooted, all files including .mp3s are back!
The device fails to be formatted with windows and any other 3rd party applications. Different errors generally occur including one whilst using a fat32 formatter which states that the partition has collapsed…
Firmwares cannot be installed automatically or manually. They don’t have any effect on the device and just cease to exist once the player has been unplugged from the computer.
Other than that the device works perfectly fine on the 01.01.20 firmware.
Helllllp!
