The lowest volume setting is too high for background music, imo. Is there any way to decrease the volume more? I don’t notice any difference between the high and normal settings with this problem.
It is only the radio that is too loud on the softest setting.
I too have difficulty with the volume being too loud even on the quietest setting, especially for FM Radio. ![]()
According to my experience, reducing the volume of the radio only works in the upper half of the displayed volume range. In the lower half, pressing the “-” button only continues to shrink the volume bar without actually reducing the volume.
Any solution yet for this problem?
Radio FM is useless to me, minimum volume is too high… I don’t understand why it was designed this way
Message Edited by picotoSANSA on 01-23-2010 04:36 PM
try latest firmware with europe option. Should lower the lowest volume step by a far margin.
No. The problem didn’t make it on the developer’s ‘to-do’ list yet, but should be addressed in a future update. I agree it should have been Priority #1 as the original Clip suffered this malady out of the gate, but alas . . . whadaya gonna do?
No. The problem didn’t make it on the developer’s ‘to-do’ list yet, but should be addressed in a future update. I agree it should have been Priority #1 as the original Clip also suffered this malady out of the gate. One would think that this would be the 1st thing they checked for in the Clip+'s initial QA testing, but alas . . . whaddaya gonna do?
Thanks, at least it will be solved eventually. Same for the Clip?
The same problem with the original Clip was fixed long ago in a firmware update.
Didn’t check that (I use the + now) :))))
I also find theminimum volume too loud. I like tolisten in bed before going to sleep. Without surrounding noises I’d prefer about half the loudness for the minimum volume setting.
subsequent stepsin loudness when increasing the volume are a lot smaller than the step from 0 to minimum volume …
Here is a solution for the clip jam. It should apply to most things (set replay gain on and to minimum)
I posted in detail here: SanDisk Clip Jam volume adjustment
