SanDisk Clip Jam volume adjustment
I recently bought the SanDisk Clip Jam after having used my older SanDisk for many years. I like to go sleaping listening to music, the volume set very low.
Regretfully the Lowest possible volume setting on the Clip Jam is still too loud for me. I’m not able to adjust the volume in small steps.
In the system setting I’ve set the volume to normal, high being the only other possibilty. My old SanDisk allowed me to control the volume in a much finer way.
Anyone knows how to change this?
Bit late to the party here!
The answer is to go to settings on your Clip jam, go to replay gain. Turn It on so that it says
Replay gain: Songs
And make sure to set the dB to the main (1.5DB on my one).
(To change the DB and The preset thing for replay gain press the ok select enter thingy over the selected option until it goes to what I said.)
Also yeah I agree it’s not quiet enough anyways at least I’m not using Spotify with ads!!
Better late than never, Agdni :wink:
I’ll give it a try …
