Can passport be used as drive & for backup?
I received a Passport external drive for Christmas.  I would like to use it both as an external drive to hold all our photos, and as a backup for my computer.  Is it possible to do both?  If so can someone explain the steps to me?  I just installed it and back up my computer, but if I need to erase data & reformat that’s fine.
Certainly you can use the drive as a storage unit and also use the backup application, for example you can create two different partitions use one for the software and the other for storage.  I found this WD article I think it will guide you to the right path.
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=3865&p_created=1258601352&p_sid=iTx6qtkk&p_accessibility=0&p_redirect=&p_srch=1&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MSwxJnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD0zODY1&p_li=&p_topview=1
