Can not open file for read
I installed the SanDisk Secure 3.02 software on the “SanDisk ULTRA USB 3.0” drive.
In this protected usb drive I copied some excel files.
One of these files (the one that contains the excel macros) when I save it appears the error window “can not open file for read C./user /…/ AppData / Local / Temp / SanDiskSecureAccessV3 / …”. However, the rescue is done.
If I open and save the other excel files (which do not contain macros) there are no problems.
Can you help me? I have pc with Windows 10.
Thank you
I am getting the same error whenever I try to save an excel file that I have in the vault.  Sometimes they save just fine, next time, I get this error.  It’s quite annoying.  Is there any resolution found for this yet?  BTW, I do NOT have macros in these files.
Hi! Guys, is there anyone have an update to fix this issue? I also got the same errors like yours. Hope, anyone from Sandisk support response some tips how to fix this. -TIA
