Can not hear songs from my microsd card - help
Hi!
I downloaded songs directly to my sandisk 8GB microsd (i added them via the microsd adapter)
when I entered the card into the slot on the sansa fuze I got a message to go into this forum for help
why is that?
Tnx,
Royi.
Ok you plug the card into a reader on your computer, and added the music then pluged it into your player and it gave you an error message? Try taking the card out and putting it back in perhaps it didint load right and the fuzecould not build the library file. If this does not help, plug the card into the computer and then delete everything off of it, then plug it back into the fuze and add the music onto the card with it plugged into the player
I would also suggest putting the card in the Fuze and loading music on it that way.
