I’ve got arlo camera with a smarthub which is no longer recording any videos locally to my sandisk extreme plus 256GB microSDXC card. I’m getting notifications from my cameras, but oll of sudden my SD card won’t store any clips. I spent multiple 10s of hours with their support, troubleshooting it and tried removing, reconnecting and formatting the SD card multiple times but nothing. It seems like my SD card is defective and its been only few months when i bought it. Should I just buy some other better SD card?
The camera not recording to an SD card could be due to some issue and require troubleshooting. Try using the chkdsk to fix any issue with the card or try these troubleshoot for card errors.
It appears that your SD card may be defective. Before purchasing a new one, you can try using a different SD card or reformatting the current one with another device. If these steps don’t resolve the issue, you may want to consider purchasing a new, high-quality SD card from a reputable brand.
