I just bought a sandisk 64gb sandisk sdxc micro sd card. When i inserted it in my switch, it just didn’t recognize it. It works perfectly fine on my computer tho. I tried putting in other micro sd cards but no luck either. I think my port might be broken or something. Also, I tried formatting the card to no avail. Could someone help me?
Well, if you feel your port is broken then you should get a new one or check if it is covered under warrenty. Hope this helps. Cheers! ![]()
Regards,
