I am so frustrated with Rhapsody, there software seems so buggy. Years ago I was a subscriber and after a couple of clips not working anymore I switched over to Zune. I thought I would give them a try again but version 6 did not seem like any improvement. I could not sycronize certain albums, not having any clue why (even though the album downloaded just fine). Tracks would show up in my playlist that I never selected and you can’t use purchased music with version 6.
So I unintalled Rhapsody and decided to use my clip+ for my purchased music. It seems easy to just drag and drop music files into the clip but I have no idea how to build a playlist. I am subscribing to XBox music pass and will use my Zune for subscription music, but as I said will use the clip for my owned music.
When I received the Sansa clip+ I received a software cd but my computer does not have any cd/dvd drive. I thought this would not be a problem as I should be able to download the same thing, but I did not see any software downloads for the clip. Can I download the software to create playlists or is it simply for firmware upgrades?
I have a Yogo Pro 2, which uses windows 8.1. It seems like I can use windows media player to sync music but my concern is it will sync all my music, which I do not want. Can I select just playlists or filter for mp3s or mp4s?
Gary
