Hello
I upgrade the sansa clip (2GB with radio) to this firmware using the drop firmware file to the root directory of the clip.
I then disconnected it and it rebooted, did the upgrade and database rebuild.
I looked at the menu and it indeed said that the version is 01.01.20.
Then it started saying all the time that battery is low and turns off.
I tried charging it for a few hours but this doesn’t help.
It just turn on for less that 10 seconds and turns off, all I can see is a battery low error and the battery with a cross on it.
How can I revert the version? I tried the method with starting it and holding the on button for 10 seconds but it just dies before resetting.
Please help me as i really liked this player before this problem with the upgrade.
Thanks
