The latest firmware update does address this issue and does allow you to copy audiobook files (not just audible…I copied just plain old mp3 files) into the folder: Audiobooks. There is also a Podcasts folder, but I have yet to use that one.
The files that you copy into the Audiobooks folder will get automatically bookmarked once you start to play one of them. You can then switch out to your music files, and whenever you come back to the audiobook folder files, you will be prompted to “Resume Playback” or “Start from Beginning”…sa-weet, eh?
The only issue I ran into was that the audiobooks that I loaded were broken into several (often many) separate mp3 files per book. Using the method I just described, you would still need to recall which sub-file you last were listening to, in order to resume the playback at the correct place in your book…make sense?
Anyway, a simple way around this (thanx to tk421 in this thread: http://forums.sandisk.com/sansa/board/message?board.id=clip&thread.id=6790)was to just merge the individual sections (files) of the book into one large mp3 file. This way when I return from listening to some tunes and “resume playback” on my book, I just select the overall book file (the merged one) and it starts exactly where I left off last time I was there (it’s bookmarked!).
This is a very useful upgrade to this player, if you use it at all for audiobooks, that are not from Audible.
There may be other ways around the multiple-file/merge issue with books, maybe subfolders work…dunno…I just merged them with “MP3 Merger” (freeware)…I’m sure there are numerous ways to do this as well. This one works so simply, so I stuck with it.
In summary, if you are thinking of *not* buying the Sansa Clip becauseof concerns of audiobook bookmarking, etc, scratch that concern off your list. It is a great audiobook player.
Message Edited by yoyorobbo on 05-27-2008 11:43 AM
Message Edited by yoyorobbo on 05-27-2008 11:48 AM
Message Edited by yoyorobbo on 05-27-2008 11:49 AM
