Audio Book Playback
All right.  Just got the little 8MB SanDisk Sansa Clip+    I loaded my first audiobook on the thing, and when you look at it on the computer, when you are loading it, it appears to be in the exact right order.  Then I go to play the **bleep** thing and it takes it on itself to jump from chapter to chapter.      I have had a couple Ipods and a Philips Aria product before, and never had this problem before.   The numbering on the names seems to be correct,  is there some other numbering I need to be looking at?   Does ANYONE have any ideas?   I do not understand why this thing refuses to play items in the order they are listed on my computer.  (Or in the Sandisk folder on the player.)
HELP…I am very close to taking it back.   I do not want to have to go through and rename everything on every book I load.  The book I am listening to has 196 parts.  Am I going to have to rename every one of them in order fo make it work??
My, that is little! Ususally they’re 8GB.
:stuck_out_tongue:
My, that is little! Ususally they’re 8 GB.
Excellent point.   :smiley:
