I don’t know what your software designers (do you hire only retarded ones, one might wonder?) did to make it so, but my folder view list of tracks is totally chaotic.
It lists tracks alphabetized, but only in bites, then it moves on to another batch, alphabetized correctly, then another and another. Instead of starting from A and moving to Z, with all of them, sequentially.
Numbers are all garbled up too. Tracks starting with 0 or 1 are buried somewhere, while my whole list starts with 2. Go figure.
Can you, dear SanDisk employee, who is reading this, please forward this to your software gurus?
All you need to do is start with 0. Then move onto 1. Next comes 2 3 4 5 6 7 8 9.
Then a b c d e f g h i j k l m n o p q r s t u v w x y z.
And the second letter in the name follows the same pattern, etc.
This makes finding a song really straightforward, instead of impossible!
Simple!
Go to it! Go, go, go!!!
