Album artwork
My fuze shows the album cover for some albums but probably less than half.  They were all ripped using media player.  Any thoughts?
Cheers
Steve
If you can see them all on Media Player…just a thought…try adding one album at a time instead of a huge list. It’s not nearly as convenient, but it’s worth a try…remove a couple of the ones that didn’t work before and try again this way.
Also…look in Windows Explorer/My Computer at the files…if the album art files are there with the music files, then you could always drag and drop too.
