Is it possible to add a new song to an already established playlist?
If so I sure would appreciate help.
Thanks,
Jess
Thanks,
Jess
Did you use windows media player? If you did, open windows media player and click on your playlist. Click on edit in pane list at the bottom of the screen. Add your songs to the pane list, I drag and drop them, then click save playlist, click sync at the top of wmp. Plug in your player to the computer and click start sync at the bottom of the pane list - mine starts to sync on its own. When it is done syncing, disconnect player.
Message Edited by styxblue on 04-06-2009 07:57 PM
