Hi …
I just added the Album Art picture as How To video. But it’s not appear in my fuze. Why?
I copied the jpg inside the folder and rename to ‘Album Art.jpg’. Is that all? Is there something I miss to do?
Hi …
Hi … I read through the forum and I reduce the picture size to 30 KB and I put two pictures as ‘AblumArt.jpg’ and ‘Folder.jpg’ and now it’s work … ![]()
I have found a good software to make easy (and quick) album art. You can have a look :
Message Edited by cosmocat on 01-04-2009 04:07 AM
Message Edited by cosmocat on 01-04-2009 04:08 AM
Either one will work (you don’t need both), but be sure to use a space between ‘album’ & ‘art’.
There’s a “How-To” video on the page here (#3) that shows the entire process. Very easy & simple.
Your link goes nowhere.
