Turn off the computer correctly. After each turn the cache begins to fill with the new. I reinstalled the operating system, but nothing has changed.
“Description”,“Value”,“ID”,“Attribute”,“Current Value”,“Threshold”,“Raw Value”,“Status”
“OS”,“Windows 7”,
“System Type”,“64”,
“OS Major Version”,“6”,
“OS Minor Version”,“1”,
“OS Build Number”,“7601”,
“OS CSD Version”,“Service Pack 1”,
“Processor (CPU)”,“‘Intel(R) Core™2 Quad CPU Q9550 @ 2.83GHz’”,
“CPU Count”,“4”,
“Installed Memory (RAM)”,“4094”,
“Computer Name”,“SERGEY-PS”,
“Model”,“SanDisk SDSSDRC032G”,
“Serial Number”,“123125400847”,
“Firmware Revision”,“2.0.0”,
“ATA Major Version”,“ATA8-ACS”,
“ATA Minor Version”,“Reserved”,
“SATA Generation”,“3”,
“Worldwide Naming”,“5001B447B66D810F”,
“Supported Features”,“DSM (TRIM), SMART, Security, NCQ, APM”,
“”,“”,“05”,“Reallocated Sector Count”,“100”,“0”,“0”,“N/A”
“”,“”,“09”,“Power On Hours”,“100”,“0”,“31”,“N/A”
“”,“”,“0C”,“Power Cycle Count”,“100”,“0”,“11”,“N/A”
“”,“”,“AB”,“Program Fail Count”,“100”,“0”,“0”,“N/A”
“”,“”,“AC”,“Erase Fail Count”,“100”,“0”,“0”,“N/A”
“”,“”,“AD”,“N/A”,“100”,“0”,“9”,“N/A”
“”,“”,“AE”,“Unexpected Power Loss Count”,“100”,“0”,“0”,“N/A”
“”,“”,“BB”,“Reported Uncorrectable Errors”,“100”,“0”,“0”,“N/A”
“”,“”,“E6”,“% of Total Write/Erase Count”,“100”,“0”,“30”,“N/A”
“”,“”,“E8”,“Available Reserve Space”,“100”,“5”,“”,“Pass”
“”,“”,“EA”,“% of Total Write/Erase Count (BC Blocks)”,“100”,“0”,“21”,“N/A”
“”,“”,“F1”,“LBA Sectors Written”,“100”,“0”,“509968582”,“N/A”
“”,“”,“F2”,“LBA Sectors Read”,“100”,“0”,“158616431”,“N/A”
ExpressCache Command Version 1.0.94.0
Copyrightй 2010-2012 Condusiv Technologies.
Date Time: 10/27/2012 12:53:14:461 (SERGEY-PS #10) <<<<<<<<<<<<-------------------- this number increases after every reboot
EC Cache Info
Mounted : Yes
Partition Size : 29.82 GB
Reserved Size : 3.00 MB
Volume Size : 29.82 GB
Total Used Size : 1.53 GB
Total Free Space : 28.29 GB
Used Data Size : 1.46 GB
Used Data Size on Disk : 1.52 GB
Tiered Cache Stats
Memory in use : 1024.00 MB
Blocks in use : 8184
Read Percent : 5.31%
Cache Stats
Cache Volume Drive Number : 1
Total Read Count : 35882
Total Read Size : 1.16 GB
Total Cache Read Count : 3087
Total Cache Read Size : 154.98 MB
Total Write Count : 3918
Total Write Size : 123.72 MB
Total Cache Write Count : 1289
Total Cache Write Size : 13.12 MB
Cache Read Percent : 13.05%
Cache Write Percent : 10.61%
After last reboot
Date Time: 10/27/2012 13:9:49:47 (SERGEY-PS #11)
EC Cache Info
Mounted : Yes
Total Used Size : 793.38 MB
Total Free Space : 29.04 GB
Used Data Size : 717.13 MB
Used Data Size on Disk : 784.88 MB
Tiered Cache Stats
Blocks in use : 0
Read Percent : 0.00%
Cache Stats
Total Read Count : 23994
Total Read Size : 927.63 MB
Total Cache Read Count : 1364
Total Cache Read Size : 21.11 MB
Total Write Count : 2027
Total Write Size : 103.28 MB
Total Cache Write Count : 266
Total Cache Write Size : 2.23 MB
Cache Read Percent : 2.28%
Cache Write Percent : 2.16%
