Accidentally deleted a voice file from Sansa Clip. Help!
I recorded something under the Voice function and saved it. I later accidentally deleted the file directly from my Sansa Clip. Is there anyway to retreieve the file?
thanks. I did run the program, but it would not search my Sansa Clip. When I tried to recover a file in a specific location I got a message saying “The folder My Computer/Sansalip cannot be used. Please choose another folder.”
Make sure the Clip is connected in MSC mode (just in case Recuva lets you select an MTP device which probably won’t work).
