Hi. I took some bad advice off the web and erased the clip using disc utility on the mac…The disk image is still on my desktop, but there are absolutely NO files. Is there a way to download these files?
http://forums.sandisk.com/sansa/board/message?board.id=clip&message.id=21556&query.id=101787#M21556
Well, after my initial blind panic I searched some more and found a solution on the above link. Thanks Lolyton, you’re a genius…
Message Edited by Azriel on 02-13-2010 07:50 AM
