Would pretty much any work? even my scoshe ipod charger… it has usb in.
Never hook ipod wires up to sansa’s…if they do fit, they will fry your sansa:cry:
i know that the charger is usb in so i can plug a usb cable into it.
Yeah there are a LOT of various kits and manufacturers. Google search or go on ebay. Of just go to Radio Shack. They are commodity products now- and dirt cheap.
I’m am under the impression that while ipod docks will damage the Sansa, usb chargers with an ipod connector ARE OK to use on the FUZE.
Is this true?
i should be find cause my “ipod charger” uses usb to connect not the propietary connector.
bump.
I just found mine at walmart. Simple to use. It fits the USB cable. Any usb cable, so it will say that on the packaging. And yes it’s a good one. Only $15. I have it attached to my docking station at home. I don’t use my car one very much because I either charge at home or at work. I think I’ve used it once and it worked fine.
I think this is the one I have, looks like it.
http://www.walmart.com/catalog/product.do?product_id=7081041
Message Edited by Dalaug234 on 12-08-2008 04:17 PM
