burntorange/Tapeworm wrote:
Sorry, figured out the _quote_ function, but accidentally clicked the _solution button_, not knowing it’s a done deal. I guess I’m about as screwed as it gets. I’ve been messing around with batch tagging my wma files, but not convinced it’s the source of the problem. I’ve started shopping for another 8gb micro card, as I don’t think I can do much more, besides take the player back. Good thing is that the retailer gives you 3 months to return it …no questions asked. I’d still like to make it work, but I’m at the point of diminishing returns …plus dealing with a water main break yesterday, a flood two weeks ago, and a sick dog. I just wanna listen to some music.
You, as the OP can change the Accepted Solution status in the Options (upper right-hand corner of post).
I’d thoroughly check out the card or try another one first. It’d be silly to return the player and get another one, only to find out you have the same issue with the new one.
Thanks for the heads-up on the Accepted Solution reversal. However, I may have finally isolated the problem, as the H2testw results don’t look good. I believe that the test shows that only under 1.8gb of 8gb of memory is functional.
Here are my Sandisk 8GB micro sd card H2testw app test results:
Warning: Only 7953 of 7954 MByte tested.
The media is likely to be defective.
1.8 GByte OK (3964864 sectors)
5.8 GByte DATA LOST (12322880 sectors)
Details:5.8 GByte overwritten (12322880 sectors)
0 KByte slightly changed (< 8 bit/sector, 0 sectors)
0 KByte corrupted (0 sectors)
1 KByte aliased memory (2 sectors)
First error at offset: 0x0000000078ff8000
Expected: 0x0000000078ff8000
Found: 0x0000000078ff7c00
H2testw version 1.3
I also tried transferring about 4 GB of wma files over to the micro sd card from laptop to sd card reader, and found that only the first third or so of the cd tracks will play, as usual. When I try to play a corrupted track, I get the windows media player prompt:
“The file you are attempting to play has an extension (.wma) that does not match the file format. Playing the file may result in unexpected behavior.” Then it asks if you want to try to play the file, but it won’t play. The same files on my laptop & pc play perfectly. That could explain why the Fuse gets buggy after loading several dozen cds.
The OEM packaging from the micro was new, but their European market address appears on the back, although it shipped from CA. It’s possible that the card was legit, and that I may have unwittingly juiced it with static, causing the damage, although I’ve been fastidious all along. My guess is that in such a case the card would more likely fail completely.
Evidently my compromised Sandisk 8gb micro is guaranteed for 5 years, assuming no abuse or accidents. So, I might be able to recoup my expense or get a replacement card. In the meantime, since I’m not sure I can’t count on that as being more wasted time, I guess I’ll order a second micro sd card. The original was purchased on eBay I think. I could get another card for $15 from an amazon store front. Noticed that r.shack carries sd cards, and the sale prices are pretty competitive. Not a Wmart fan, but they charge $23 delivered to the store. Will think about it, maybe even bump up to 16gb.
Regarding returning the Fuse, I would never have returned it for another Fuse, if it hadn’t worked out. I meant to say, that I would consider returning the Fuse to buy some other brand of MP3 player, probably Zen or Zune in the same price range. However, from what I’ve read the Fuse, despite it’s flaws, it has better sound quality, loads music faster, and has less convoluted software compared to other players in the same price range.
Anyway, thanks again for the creative angles on the problem. I was definitely ready to give up on the player, before trying the suggestions. I’ll leave my post unsolved, until I test a new card out, and hopefully report again soon. I really appreciate the forum support. Have a good weekend.
